Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Prospective Owners
Uniden Prospective Owners - A discussion area for those interested in purchasing specific models and have questions about them.
Old 06-14-2018, 7:19 AM
racin06's Avatar
Default SDS100 vs. BD346 - A picture is worth a thousand words
As you can see, the SDS100 is receiving full bars on the signal. The BCD436 receives at best one bar. The tower is approximately 25 miles away.
Both scanners are using the Remtronix 800MHz antenna and the same exact SMA to BNC adapter, as well. Perhaps, I can post some video in the near future.
KC9IPP
Uniden BCD436HP
Icom 91AD 2m/70cm HT w/D-STAR
Old 06-14-2018, 7:54 AM
It's pretty amazing what software and program routines can do to reduce noise and discriminate the signal.
Old 06-14-2018, 9:09 AM
gonefishn1's Avatar
Oh boy, here we go again. Signal bars on one radio compared to signal bars on another? Really not very accurate.
Uniden BCD436HP, BCD536HP
Old 06-14-2018, 9:15 AM
jonwienke's Avatar
Signal bars are not particularly accurate or meaningful. A better metric is the number/duration of transmissions received by each radio when hooked to a common antenna. That said, given the conditions in the photo, the SDS100 is likely to pick up a lot more traffic than the 436.
Old 06-14-2018, 10:18 AM
mule1075's Avatar
No not very accurate. But going by the photo it is going to be quite a bit better then the 436.
Uniden BCD536HPx2/250D Motorola HT1000/GM360
Old 06-14-2018, 10:31 AM
A photo I just took.. I have a fancy camera and a lightbox..
W1ADV. Lots of radios, SDRs. API geek & home automation enthusiast. Santa Clara,CA PD/Fire/CHP ProScan feed.
Old 06-14-2018, 10:44 AM
DSC45's Avatar
Hi! What is your assessment of the comparison clarity receiving the signal, and which system are they monitoring?
Thanks,
Dave . . . ' Scanning Over New Jersey '
Old 06-14-2018, 11:01 AM
racin06's Avatar
The system being monitored is the Project Hoosier SAFE-T system (P25 Phase I). The difference between the two scanners is very noticeable...the 436 picks up maybe 30 -40% of the radio traffic and probably 50% are broken and garbled. The SDS100 seems to pick up all radio traffic with very clear audio.
KC9IPP
Uniden BCD436HP
Old 06-14-2018, 11:09 AM
racin06's Avatar
So, if signal bars are irrelevant, then why have signal bars? Uniden claims the SDS100 receives signals better from distant towers. I believe the photo confirms that claim.
KC9IPP
Uniden BCD436HP
Old 06-14-2018, 11:14 AM
DSC45's Avatar
That's some great information! Love to hear that, hope it works as well for me.
Thank you.
Old 06-14-2018, 12:28 PM
Are they on the same site/frequency?
Press CHAN and enter the control channel frequency and CHAN again on both scanners.
/Ubbe
