First off, I am open to suggestions to improve the performance but let me state the following has been tried. The attached video shows the SDS missing almost 50% of the transmissions. Sometimes the TG will flash on the screen briefly with no audio and other times it will not do anything. The radio receives conventional analog fine. It is a bit slow on conventional p25, only by about 1/2 a second. I have tried multiple antennas, locations, and systems and the performance remains the same. I like most things about this radio but its trunked performance on the three systems I have tried are not acceptable. I really don't want to return it, but I do not want the return window to pass with it working this poorly. I am pretty sure it's a software issue as it is reproducible based on the type of use and receives the signal from distant stations fine.
-Non-stock antenna 7/800 specific
-both units shared the same power source
-I have cleared user data and reloaded it
-firmware is up to date
-I have tried the database and custom FL
-I have tried different locations and different sites on the systems
-problem is consistent on p25 phase I/II, SmartZone, EF Johnson Atlis P25.
Video on the CT State Police system.
https://www.youtube.com/watch?v=V0pqeRp4vLU
See attached log file with multiple failed messages.
