Old 04-10-2008, 09:17 AM
Default delete BR330T preprogrammed systems?
Is in common practice to delete the myriad of factory preprogrammed systems, 99% of which are not applicable to my current location...?
Im having a little trouble figuring this scanner out, and was just wondering if I should start with a clean slate, to make navigating a bit easier. Thanks!
Old 04-10-2008, 09:25 AM
W5JSS's Avatar
Absolutely! Although you may wish to make a back-up copy of it using software first.
Every scanner I have ever owned gets the pre-programmed stuff wiped out first thing.
I really think those systems are there just so you can immediately start scanning if you are one of the types that have to put batteries in it as soon as you get it to your car in the parking lot.
Old 04-10-2008, 10:44 AM
n2mdk's Avatar
Yes you can get rid of everything you don't want. If you download the UASD software, even the free copy has all those preprogrammed systems loaded into it.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 04-10-2008, 11:02 AM
cpuerror's Avatar
I would get rid of them, its just useless having to wade through all those systems you will never use.
http://scannow.org - Download FreeSCAN
Similar Threads
Another newbie question - BR330T Quick Keys scrosby2 Scanner Programming Software 5 08-28-2007 12:50 PM
Handling systems too big for your limits Jay911 Uniden Scanners 15 08-28-2007 08:45 AM
Resetting BR330T for UK Frequencies JohnnyStar Uniden Scanners 1 04-24-2006 09:19 AM
What the...? UASD help needed! whacker Scanner Programming Software 4 03-23-2006 11:19 PM
BuTel software release first free software for Uniden BR330T! Butelsoftware Scanner Programming Software 0 11-03-2005 07:41 AM
