Clarification of the P25 AGC Settings Instructions
Any help (clarification) would be greatly appreciated.
Issue # 1 – Instruction # 4
“While receiving a P25 signal, hold F then tap the scroll knob. The scanner displays the current P25 RES TIME parameter setting (see below for option details).”
Q-1) hold F… = activate the “F” indicator on the display screen; True or False?
Q-2) … then tap the scroll knob = de-activate the “F” indicator on the display; True or False?
Issue # 2 – Instruction # 6
“F+rotate the scroll to select another setting.”
Q) F+rotate = activate the “F” indicator on the display screen then rotate the big knob; True or False?
