Old 06-15-2008, 03:44 PM
Ganuke's Avatar
Default BC92XLT Issue ?
Hello,
I have been a long-time reader and sometimes poster here. Currently there is an issue with a scanner that I am wondering if anyone can assist with ...... or even confirm it being an issue with this scanner. It is a Uniden BC92XLT scanner which is actually owned by a cousin of mine. He has owned this scanner for about 2 years now so I'm sure by now the warranty on it has expired. To the best of my knowledge my cousin has not dropped or otherwise put this scanner through abuse. In fact because of the problem he has had with it..... he has rarely used it. As I said..... I posted here before in regard to my own scanner ( A Radio Shack Pro 92 ) and have received very good help and information from members here. So really...... while a post-warranty scanner could not be replaced by the manufacturer ..... still would like to know what the real problem with this scanner could be and if it is a known issue with this scanner.
Ok...... that problem with this Uniden BC92XLT is that it constantly stops on low band frequencies that have been input into the scanner. These would be frequencies such as in the 47.XXX range and 33.XXX range. My cousin had told me that the scanner would just ' get stuck ' on various frequencies. It is when I brought it home to tinker with the frequencies and see if I could figure out what the issue may be that I came to realize the problem ( at least having had it for a few days now ) is with just the low band range.
The scanner will stop on any and all low band range frequencies and literally be stuck there. When I first took the scanner home I filled it with known active frequencies that I have in my Radio Shack Pro 92 scanner ..... figuring those would mostly all work well in his scanner from his house which is just 3 miles away. After inputting those...... as my cousin had said..... it started getting stuck on frequencies all of which after having had it for a few days are in the low band range as I said above. In fact...... I just had to lock out another one as I have that scanner on while I write this.
I have tried turning the squelch slowly and completely clockwise ...... and it still remains stuck on any low band frequency that it stops on with the ' snowy ' noise. I also put a Diamond RH77CA antenna onto my cousin's BC92XLT in place of the stock antenna it came with thinking that it might just be the result of a crummy stock antenna that is causing the thing to get stuck on all the low band frequencies. Doing that had no better result as the scanner still kept getting stuck on the same low band frequencies that I had input into the scanner.
The ' good ' thing is that the area in which my cousin and I live has recently been moving their scanner frequencies for such things as Police, EMS, and Fire to a higher range above the low band area. Prior to this most of the police, EMS, and Fire frequencies were in the low band range. That is why my cousin had gotten so frustrated with it continually getting stuck on most of the frequencies that were needed to pick up most activity in our area. Now with this recent move of the Police, EMS, and Fire frequencies up the band range ....... I've input the newer higher range frequencies into his scanner from what I had in mine ( which I got in large part from here at Radio Reference. )
Hopefully all frequencies that can be found in our area move out of the low band range which would seemingly make this scanner completely useful for my cousin finally. Also my cousin didn't just completely ignore the issue from when it first started. He was twice at the retailer that had sold him the scanner and told them what was happening with it getting stuck on frequencies. He did this about 2 or 3 times..... each time the place would keep the scanner for a few days...... call him back and said they had corrected the problem. My cousin would then go to pick it back up only to find out a short time later the BC92XLT was still getting stuck on the same frequencies ( which now I know are all in the low band range. ) It was going to be a 4th time my cousin went back to the retailer who sold him the scanner to try and once again get th problem with the scanner fixed but before doing so he had called them to explain that the problem with it was still going on. Whoever took the call at the retailer told him that they remember him and the issue with his scanner and that they had fixed it and there was nothing wrong with the scanner...... this after my cousin brought up about having the thing just replaced as it was then still under warranty. That phone call concluded with the person from this retailer again saying they had fixed the problem and there was nothing wrong with the scanner ....... and that he must be inputting the frequencies wrong so it would not be replaced even though at that time it still had warranty coverage.
I actually find all the detailing about this now..... like I said above I'm sure much too late for anything to be done about it. Had I known fully about this back when his scanner was still under warranty I'd of called the retailer myself ...... and if he wasn't given a replacement ..... would have emailed a long ( longer than this post ) and not so happy letter about what was going on with this scanner and the retailer who sold it to my cousin..... to Uniden myself. My cousin is one who doesn't like to raise too much of a fuss on stuff. I on the other hand am one to raise a big fuss if I feel a consumer is getting messed over.
Anyway..... long post I know...... and basically wondering if anyone knows of a possible solution to this problem with my cousin's BC92XLT ? At the least ...... does anyone know of this being an issue with this particular scanner ?
Ganuke
Old 06-15-2008, 04:30 PM
CStarr59's Avatar
I've had my bc92xlt for about 2 years and it has always worked perfectly. About 2 months ago it started just as yours, getting stuck on low band frequencies. I assumed it was electrical interference but it has gotten worse. Even outside it does it now away from all electrical distractions. So basically it sits unused in my scanner drawer. Recently I purchased a psr-100 and it has made me a happy scanner again. I really don't think the bc92xlt is worth fixing at this point. It gave me many happy hours of service, but now its time to move on.
PSR-100
PSR-300
Old 06-25-2008, 02:40 AM
Ganuke's Avatar
Yep..... this particular scanner I have of my cousins I just wondered if this was a common happening for the thing..... like a known issue. From lack of response in this thread ...... maybe it isn't and he ended up getting one of the few BC92XLT scanners that refuse to bring in low band frequencies without getting stuck on them. And with wondering if this was a known issue for this scanner..... basically wondered if there was any quick / easy fix for it. I agree that it would not be worth the effort to open the scanner up to try and diagnose the problem myself...... and not sure I'd even know where to start for that matter. And the warranty on this scanner has come and gone. I would have liked to have known the lack of assistance my cousin was getting by the people at the retailer where he had this scanner purchased while the thing was still under warranty. I'd of raised a nice fuss over it and not have taken any ' well you are just programming the thing wrong ' response.
But too late for that as well. And not even sure at this point in time if emailing Uniden would do any good as well with the scanner being out of warranty...... even if it was just to bring up the issue with the scanner while expecting not much in response / reaction to it. So having had this scanner of my cousin's for a bit over a week now...... basically the ' fix ' I went about with it as I described in the last post was basically just to input the known active frequencies I have in my own Rdio Shack Pro 92 into his scanner. Well..... at least the frequencies that I have which are active ...... and are above any XX.XXX low band range. After having done that and spent a few days and nights with it on to test it out making sure it didn't still get stuck on any of the higher band frequencies...... results seem good..... no sticking. And it worked out nice as I said in the last post...... since many of the fire / EMS / Police frequencies in the area we live have moved from low band to a higher band frequency just in the past few months.
With that said...... still doesn't make me happy that his scanner has this issue in the first place. And if anyone else out there knows of this being an issue with this particular scanner ..... do chime in. Or for that matter if anyone knows of some fix to it ..... chime in as well. I plan on giving my cousin his scanner back tomorrow ....... set up with the active non-low band frequencies I input which should get him using it again for the first time in a long time at least. But would be nice if there is some fix to this that can be done to get it bringing in the low band frequencies without getting stuck as well.
Ganuke
Similar Threads
Scanning USA March Issue? RoninJoliet All Other Receivers 1 12-23-2007 09:13 PM
GRE Representatives addressing P25 decoding issue? cellphone GRE Scanners 12 10-29-2007 04:52 AM
Saratoga Area Issue? ondedge New York Radio Discussion Forum 5 07-18-2007 04:44 PM
Phoenix Police Reception - Issue Solved PHOENIX_SCANNER Arizona Radio Discussion Forum 3 12-18-2006 01:00 PM
P25 UniTrunker or Pro 96 weird issue dsviper22 General Scanning Forum 6 03-01-2006 11:33 PM
