Old 09-02-2008, 02:32 AM
Default Uniden Bearcat BCT8 Trunktracker III
Hi not for sure if anyone can help me are not, but I have all the Trunk codes for my Bearcat BCT8 but there not coming in. When I first got the scanner I got them in but something went wrong with it so I had to start over. But now I can't get them to work for anything.. Can someone please help me.
Thanks.
Old 09-02-2008, 05:29 AM
Wiki Admin
First questions to ask - where are you, and what system(s) are you trying to program? City, county and state will do. Lots of areas are moving to digital, which the BCT8 cannot handle.
Our database is the place to start for this. Just go up to the top blue toolbar and click on the link 73 Mike
Old 09-02-2008, 02:49 PM
Its city and this is the information I found if it helps any. This is what the area is using.
System Voice: Analog
System Type: Motorola Type II Smartnet
Old 09-02-2008, 03:10 PM
Wiki Admin
What city? Where (state???)
Old 09-02-2008, 03:28 PM
Decatur, IL
Old 09-02-2008, 03:38 PM
Wiki Admin
Let's start with the easy stuff - here's the database entry for the Macon county 800mhz trunk...
(anything in blue and/or underlined is a link)
http://www.radioreference.com/apps/db/?sid=588
I'd step through these freqs, one at a time, and see if you have all of them as listed. If you do, one of them will have a horribly raucous sounding signal on it. That's the control channel for the trunk. NEVER lock a frequency that has this noise out.
If you don't hear it, I'd first suspect an antenna issue. If it's not the antenna, I'd jump to the Illinois forum and see what may have happened to the trunk. The database entry is dated Feb., but it's possible something has changed.
73 Mike
Old 09-02-2008, 03:43 PM
ok I got them enter but none of the TrunkTracker codes are coming in. Is there away that they need to be put in. Thats what i thank I am doing wrong.
Old 09-02-2008, 04:28 PM
n2mdk's Avatar
First there are no codes there are frequencies and talkgroup IDs. If you have the frequencies n can you hear the control channel when you manually go through the frequencies. It will be one frequency making noise.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 09-03-2008, 01:22 AM
sorry, n2mdk I meant to say frequencies and talkgroup IDs. I am new at this. I have all of the frequencies and talkgroups IDs enter but the ID's are not coming in. I was looking to see if I had enter them wrong. I don't have the manual to this TruckTracker.
Old 09-03-2008, 03:34 AM
Send a message via Yahoo to tcb4ep
make sure the trunking starts at the beginning of a bank..
Old 09-03-2008, 06:07 AM
Wiki Admin
Well if all you need is the owners manual, download it from the Uniden website - here's the URL...
http://www.uniden.com/pdf/BCT8om.pdf
And to get started understanding trunktracking (not trucktracking - I get a good laugh every time I hear that...) I would read the overview section of the following (remember anything underlined and/or in blue is a link - that's true in the wiki, too....)
http://wiki.radioreference.com/index.php/Trunking
73 Mike
Old 09-04-2008, 01:47 AM
Thanks guys. I got almost all of the TrunkTracker IDs working. Not all of them but most of them. Thanks again.
Old 09-04-2008, 02:01 AM
always pass on what you learn,,. :-)
Similar Threads
Fs: Uniden Bearcat Bcd396t (ne) ozztheozz Old Classifieds Archives 5 11-06-2008 11:25 PM
FS: UNIDEN BC898T Trunktracker III northzone Old Classifieds Archives 2 01-10-2008 12:18 PM
FS: Uniden BC898T Trunktracker III northzone Old Classifieds Archives 1 12-30-2007 04:01 PM
Uniden Bearcat BC898T Tones Question? wm820 Uniden Scanners 2 10-10-2007 10:27 PM
