Aloha to all. I'm a newbie with my new BCD396T so please bear with me. I've been trying to setup my new scanner but I've run into some difficulty. I've downloaded the BuTel ARC396 software and updated my scanner with the latest fireware. I used the BuTel software to download the P25 trunk system to my scanner and here is the link to the frequencies:
http://www.radioreference.com/apps/db/?sid=5976
After I got this info downloaded to my scanner and press "SCAN", the scanner's display will display "ID SCAN" but I do not hear any transmissions. I adjusted my squelch and tested my scanner with a conventional system and audio and receiving is fine for the conventional systems. Only when I try to listen to the P25 system, I am not able to hear anything. From some research and some help on another forum, a member mentioned that I would need to have the "talkgroup ID" and "control channel" info for the P25 system in order to hear the transmissions. He mentioned to me about using the "IDTracker" software to capture the trunkgroup ID info but I would need to find out the control channel info somehow.
I would appreciate it if someone could steer me in the right direction and help me figure out how to get the P25 system to work on my scanner.
Mahalo in advance.
