Old 11-22-2008, 5:28 PM
Default Firmware Update BC996T
Problem: am having problems upgrading the firmware in my BCD996T.
Current firmware: v1.03.11
I have used the BCD996T_USAD program to backup my scanner settings and confirm PC to scanner communications are OK - COM1 at 115200. I also use the Proscan program to communicate with the scanner and it works file.
Problem: BC_VUP (firmware update) program doesn't "see" (read: communicate with scanner) and so wont update firmware. I have tried different versions of the BC_VUP program. They don't work. I have tried 2 different laptops to the scanner (in addition to the original PC) and the BC_VUP program just doesn't see the scanner even after the (press 6 & L/O keys) to put the scanner in (remote program?) mode so scanner is ready to accept firmware update.
I have read the followed upgrade directions to the letter several times. I have reset my scanner to factory defaults (after my backup) and still the BC_VUP program fails when trying to see the scanner.
Q.) Anyone know a trick to get the scanner into (remote program mode) so that the BC_VUP program will inject the BCD996T_V1_04_12.scn firmware into the scanner? I'm trying to get to the release 3 and I know I have to do all the in between steps to get there...
Old 11-22-2008, 6:19 PM
You don't just press L/O 6, you do it as you are powering on. The scanners display will light up but be blank.
Old 11-22-2008, 7:29 PM
Default Firmware Update BCD996T
Thanks RDale.
I've tried that (L/O & 6) using both the on/off switch and power plug in the back.
At all times the display screen changed to a blank "green" screen...then update failed...
Strange.
Old 11-22-2008, 9:43 PM
Viper43's Avatar
Are you using the front serial port, the back won't work for upgrades
V
Old 11-22-2008, 10:35 PM
Default the Front?
Viper43 - R U kidding?
I saw nothing in the instructions that stated that you have to use the front (serial port) for the upgrades...
Nothing. I can try that tomorrow.
R U serious?
Old 11-23-2008, 2:12 PM
Viper43 !
That was it!!!!
I had no clue you HAD TO USE the front port on the BCD996T.
I've been using the back (DB-9) for a few years to do "everything" monitor - Proscan - Butel...
aways worked fine.
Uniden download didn't say a thing about "you have to use" the front port of the scanner for the firmware update...
After I used that front port...upgrade worked just fine....
Thanks again!
Old 11-23-2008, 3:00 PM
Viper43's Avatar
Nope, I wasn't kidding Glad you got it working!
V
Originally Posted by TAnderson View Post
Viper43 !
That was it!!!!
aways worked fine.
Thanks again!
Old 11-23-2008, 3:07 PM
Wiki Admin Emeritus
These are the sort of little tips that I've been trying to accumulate in a wiki article so it doesn't have to be repeated time and again.
http://wiki.radioreference.com/index...anner_Firmware
If anyone has any more tips, particularly with the upcoming 15/246 firmware updates, please post them
73 Mike
