Old 02-01-2009, 10:05 PM
Default APCO-25 trunking and BC796D settings.
I have a simple question, what settings do you use for apco 25 trunk banks? do you use plan 1, or plan 2? or none, also what are the squelch settings?
Matt
Old 02-01-2009, 11:39 PM
Deeke's Avatar
If i remember correctly, it has to do with the frequencies(highest). I read it in the manual when i had my 796 but i can't remember.
The manual can be downloaded here if you don't have one.
http://www.uniden.com/pdf/BC796Dom.pdf
Old 02-02-2009, 02:29 AM
torontokris's Avatar
Send a message via Yahoo to torontokris
When trunking the squelch should not make a difference.
I normally suggest a middle settings (just in case ur also going over conventional freqs in another bank you wont miss them, or on the opposite side get static)
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
