DeLuo GPS receiver works too
For those with a DELUO UNIVERSAL GPS receiver:
You will need:
Your 996T scanner
Multimeter (to check voltage and wires)
Philips screwdriver
Soldering Iron (no static one to void damaging other components)
Shrink tubes (to isolate the wires)
solder and solder flux
and no you dont need the hot sauce.
I did run into some road blocks trying to get power from the scanner into the GPS receiver and I wanted to share this with everyone. Could be of help to someone?!
After I solder the 7805A voltage regulator, I plugged in the GPS and ... no go. The scanner still said there was no GPS connected. I proceeded to check the PINs for voltage with the multimeter. There was power coming into PIN 9 (5v) and ground on PIN 5. So, as a test, plugged the extra wire PS2 plug stripped (red and black) wires directly into PIN 9 and 5 respectively. It worked. So of course my GPS receiver wasn't wired to receive power from PIN 9 in its factory serial. Being one of those sealed plastic serials I had to cut it off the wire and get a spare serial I had around which I could open and solder.
What I did was, using a multimeter, tested each of the 5 wires to see what PIN each one connected to.
