Old 04-11-2009, 12:27 PM
Default ID Tracker II - TrunkTrack III Support?
I have been toying with the idea of adding TrunkTracker III (BCT8, BC250D, BC296D, BC780XLT, BC785D, BC796D, BC898T) support to ID Tracker II. Since the TrunkTracker IV scanners support "systems" rather than "banks", I was thinking of adding a way to map banks to systems. For example, if banks 1 and 2 are programmed to follow the same trunked system but different talkgroups, both of these banks would map to the same system file in ID Tracker so that only a single system file would need to be maintained. The bank selection from the original ID Tracker (not II) would be maintained.
The advantage of doing this would be to add the additional recording, logging, etc. capabilities of ID Tracker II not available in the original ID Tracker.
Any thoughts on this?
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Similar Threads
ID Tracker II - Version 2.0.0 Released - GRE Support brscanning Scanner Programming Software 19 11-25-2008 08:53 PM
ID Tracker II Beta 2 Available - GRE Support brscanning GRE Scanners 4 10-11-2008 09:59 AM
ID Tracker II Beta Available - GRE Support brscanning GRE Scanners 52 09-26-2008 10:34 AM
ISP Dist 52 on Greenwood Tower delallen Indiana Radio Discussion Forum 13 05-17-2008 10:45 AM
ID Tracker II - BCD396T Support brscanning Scanner Programming Software 5 09-18-2006 08:35 PM
