Originally Posted by acepilot340
I would like to put some of my personal input on my issues with the 396XT. I live in Illinois and am trying to monitor the ISP P25 system and sometimes during a transmission the scanner will just cut out. I have already checked all the CC and WX and none of that is on, but I think i have a programming issue; would anyone mind looking at my FreeScan .996 file and make sure I programmed this stuff right? I am new to this P25 stuff and want to make sure I programmed it right.
In the Illinois forum, we have discussed this issue. This is common if you're monitoring a simulcast/multi-path site. It goes garbly transmission, then you'll hear nothing, then you'll hear a reply. I'm not sure if this issue is being worked on the first firmware upgrade or not, but was also common in the T versions. Appears to be either a decoding or modulation issue. If you search around these forums, their has been many opinions on this subject.Sounds better than before, but still not as good as it should.
