Don't reset if you don't need to. All you want to do is turn off the service search bands.
To lock out or unlock a system, (even with its quick key enabled) or custom/service search:
In scan mode press Hold to hold on any channel.
Press and hold Func then press 7/Rcl.
At 'Select System' scroll to the system/search you want to lock or unlock.
Press and hold Func then L/O to lock or unlock the system/search.
Press Scan to exit. http://marksscanners.com/396/396.shtml#LO system
Hope this helps.
BCT7, PRO97<-was run over, PRO164<-to replace the 97, BCT15 w/ GPS, PRO160, PRO2096
And various other electronic toys blah blah blah blah blah
