Old 09-01-2009, 05:38 PM
Default BC-RH96 discontinued ?
Anybody know if Uniden plans to return the BC-RH96 for BCD996XT.
Would be nice if they followed some ham radio designs that have the remote head built into the unit.
Anybody know of a vendor that still has some in stock?
Old 09-01-2009, 06:01 PM
rocksteady's Avatar
There is like 4 or 5 threads on this . It is discontinued. No plans of comming out with a new one. It wasn't making any money for them. It cost more to make than the profit margin selling.
You can pick your friends, and you can pick your nose, but you can't pick your friends nose!
Old 11-05-2009, 03:40 PM
Scanner Master now has a new shipment from Uniden in stock as of 11/05/2009 add coupon code "scanremote" for an additional $20.00 off until Nov. 14, 2009
Old 11-05-2009, 03:52 PM
tampatracker's Avatar
It works for the 396XT, right?
Old 11-05-2009, 04:09 PM
Dewey's Avatar
Send a message via ICQ to Dewey Send a message via AIM to Dewey Send a message via MSN to Dewey Send a message via Yahoo to Dewey
There is a firmware update that must be performed for it to work with the XT, but yes it does.
Dewey
Old 11-05-2009, 11:41 PM
One flaw I found with the remote head.... I thought it would allow you to mount the expensive radio in the trunk (996XT) or some other hidden spot for the 396XT... but it lacked one problem... No audio output or control. Why would Uniden go to the trouble of building a "remote head" for thier high end scanners that had no audio capability? In order to have an external speaker next to the remote head, you jave to run a separate audio cable from where ever you've mounted the actual radio. From what I was told you also cant adjust the audio level from the RH. So whats the point. Perhaps that why they didnt sell. If a rep from Uniden reads this, perhaps a version 2 RH would have a built in audio amp and speaker out jack as well as the ability to control the volume level. Just a thought
Steve G.
Northern California
Uniden BCD-396XT, AOR 8000, Uniden 8500XLT
Moto MT2000, Spectra, MT500
Old 11-06-2009, 12:08 AM
guyiv's Avatar
Send a message via AIM to guyiv Send a message via MSN to guyiv Send a message via Yahoo to guyiv
It does control the audio at least for the scanner that I have seen it used with.
MNA02
LiveFireFeeds.com
Pro-95 w/ discriminator tap for UniTrunker
Pro-96, Pro-97 X2, Pro-164, BC246T, BCD396T
Old 11-06-2009, 12:13 AM
Default true
Yes, I believe it does control the audio of the connected scanner, but it uses the scanners speaker, so if you have the scanner mounted in the trunk or in the glove box, that not going to help. I was hoping for something like my spectra that I have mounted in the trunk, but the control head is up on the dash and has audio output from the remote head. I know.... It's just a scanner :-)
Steve G.
Northern California
Old 11-06-2009, 02:23 AM
ac7xc's Avatar
Send a message via AIM to ac7xc Send a message via Yahoo to ac7xc
No it only works with the T models.
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-106 PRO-92 PRO-83 TH-F6A FT897D BC346XT BC245XLT
Mac OS X, WIn7 & Linux
Old 11-06-2009, 03:38 AM
tmfok7's Avatar
The RH96 works with the T's and XT's! Here is the link to the Wiki...
http://wiki.radioreference.com/index.php/BC-RH96
One other note! There is an audio jack on the RH96. The speaker plugs into the head and not the scanner and is controlled from there.
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
Old 11-06-2009, 06:52 AM
N9JIG's Avatar
Send a message via AIM to N9JIG Send a message via Yahoo to N9JIG
BC-RH96 - The RadioReference Wiki
Actually that is not a speaker jack, they just reused some parts from the mobile scanners the "jack" location is plugged, there is no jack.
If you put the scanner in the trunk and use an RH-96 you need to run a remote speaker. The RH-96 volume control does control the radio volume, either with the speaker on the radio or one plugged into the RADIO's external speaker jack.
I have 3 in my vehicle and they work fine in this mode.
Rich Carlson, N9JIG
http://www.n9jig.com
http://www.carmachicago.com
Insert witty saying here.
Old 11-06-2009, 06:55 AM
Post
I would like to see Uniden come out with a remote head that (1) you can turn the radio on/off from the remote head and (2) you can change to any of the new display colors on the 396/996 XT and (3) at a reasonable price!
Old 11-07-2009, 07:19 PM
tmfok7's Avatar
I stand corrected! I never paid that much attention to the diagram detail to realize that the phono plug on the RH was for the control cable and not a audio connection.
______________
Too Much Fun...OK!
Similar Threads
New TAFL Search jfroot Eastern Canada Radio Discussion Forum 35 09-25-2009 10:22 PM
WTB Uniden BC RH96 colby4601 Old Classifieds Archives 0 05-02-2009 04:20 PM
Trade Uniden Bc 796D for a Uniden 996T W9NES Old Classifieds Archives 2 03-10-2009 07:25 AM
WTT:Uniden Bc 796D for a Uniden Bc 996T W9NES Old Classifieds Archives 1 06-13-2008 01:02 AM
