JimInMichigan
I'm starting to get flustered. $500 scanner and does not receive ( not saying it's the scanners fault, just frusterated ). The last time, I had inadvertantly hit the ID SCAN. Because I had only control channels installed, there were no ID's to SCAN. I learned to use ID SEARCH. That solved my problem, back then....
A little history:
I couldn't get Freescan to hook up with my radio. I read to change the c-ch output to off, and then Freescan worked. Using a file from a member here, I was able to tweak it a little and ad a bunch of ID's and alpha tag them. Freescan worked perfectly for me, on numerous occasions.
Now to my problem.
I have not heard anything all day on the scanner. I made sure I was " ID SEARCH ". I thought, ok, something, some how, got messed up. So Off I go to start up Freescan and re-upload my saved file to the scanner. Now, for some reason, Freescan will not connect to my scanner. I get " CANNOT ESTABLISH "... Bad data or incompatible ... -1
Well dang, not this again. I check my settings>c-ch output, it is set to off. I double check my com port and speed, both are correct. I pull the cable from my com port 9 and place it in com 8. I refresh freescan's port utility, and it switches and see's port 8. I try again, won't work. Switch it back to com 9. Freescan see's this change ( com 8 is now gone from the list and 9 is back ). So I know it SEE'S the scanner on the port, it just wont connect.
So here I sit. Frustrated. Can not hear anything on the scanner. It's not stopping on anything ( before when I had this problem, I got the old analog channels at least ) I double checked my squelch level ( set at 2 ). Signal strenth is 4-5 bars. It doesnt look like I have anything locked out or turned of. Next to " SO ", I have a 1 and 2. Both blink back and forth. If I push the "1" key, the "1" by SO: turns to a star. So I am assuming that turns off that system. All the numbers next to the "Group:" are showing, no stars there either.
Any idea's?
PS: Want to mention that I normally leave the scanner on 24/7. I thought maybe it needed a re-boot so to speak, so I turned it off, and back on again. I did this a couple times, no luck.
A little history:
Now to my problem.
Any idea's?
