The strange thing is that it used to work fine, I understand that it is a system wide setting Pretty much have tried everything I can think of... the system is the South Dakota state wide system of which I have it broke down into 3 seperate systems. system # 1 is the whole state and the other two are local towers only. Doesn't matter which system I'm on there still is no delay. Scanner says the delay for the system is set at 5 under menu edit system option. Setting the site hold time doesn't help the problem,
