  #21 (permalink)
Old 10-30-2009, 10:25 AM
DaveNF2G's Avatar
Uniden doesn't want to accept liability for rollbacks. It can be done; many on these forums have rolled back firmware on Uniden radios.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
  #22 (permalink)
Old 10-30-2009, 10:26 AM
DaveNF2G's Avatar
It is my understanding that people are tracking the Tompkins County system somehow. I recommend posting a survey or query to the New York Forum about it.
  #23 (permalink)
Old 10-30-2009, 11:00 AM
tampatracker's Avatar
How would one go about rolling back firmware for a 396XT?
  #24 (permalink)
Old 10-30-2009, 11:13 AM
There is no "roll-back" for the 396XT that I am aware of. The roll-back issue is for the 996T.
  #25 (permalink)
Old 10-30-2009, 11:19 AM
I'm not so sure you should give up on trying to receive this system. As I write this, I am listening to the Louisville MetroSafe system. It is a P25 Motorola Astro system which also has 12 simulcast towers. There is that garbling so some degree, which I understand is an artifact associated with simulcasting.
I can hear this system on all four Uniden scanners - 396, 396XT, 996, 996XT - that I have.
  #26 (permalink)
Old 10-30-2009, 12:48 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Correct. There have been no firmware updates for the 396XT yet.
Marshall KE4ZNR
Marshall
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
  #27 (permalink)
Old 10-30-2009, 02:43 PM
werinshades's Avatar
Send a message via AIM to werinshades Send a message via Yahoo to werinshades
Marshall KE4ZNR
I believe their was one?
No Olympics...Show us the Money!
  #28 (permalink)
Old 10-30-2009, 02:52 PM
KE4ZNR's Avatar
I stand corrected. Thanks for helping me back from a senile moment werinshades
The 1.07.00 Update which addressed the following:
This update makes the following changes to your BCD396XT scanner:
  • Remove the option for Control Channel Only for Motorola systems. All Motorola systems are trunked using Control Channel Only...this setting is unnecessary.
  • Improvement of Close Call performance against frequency drift.
  • Fixing an issue where, when on a trunked system, the priority interval is 2 seconds even when the option is set for 10 seconds.
  • Fixing an issue where a GPS alert could cause the scanner to lock up if several alert points were within close proximity.
That is the only update so far.
Sheesh...I am getting senile...
Marshall KE4ZNR
Marshall
@KE4ZNR on Twitter
  #29 (permalink)
Old 10-30-2009, 03:20 PM
I hope they have another firmware update soon.
  #30 (permalink)
Old 10-30-2009, 03:21 PM
KE4ZNR's Avatar
Funny you should mention that....
Marshall KE4ZNR
Marshall
@KE4ZNR on Twitter
  #31 (permalink)
Old 10-30-2009, 03:24 PM
DDan's Avatar
There is one just around the corner.
WhatsNew < UnidenMan4 < TWiki
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
  #32 (permalink)
Old 11-05-2009, 01:25 PM
I rolled my 396T to 2.00.07 from 3. something, whatever the factory flashed it to when it was in for repair. It was much better on the Indy / Marion county Indiana system after that.
I had to set the "use Motorola end code" in order to get the system in San Diego to work, but I didn't have it set in Indy. I use Freescan, but I had to install the Uniden program to load their canned version of the San Diego system to get it to work, that's when I noticed the end code had been set.
Uniden has some more paperweights to get rid of now, thanks to their violation of FCC regs.
from DA 09-2374
1. In this Notice of Apparent Liability for Forfeiture (“NAL”), we find Uniden America
Corporation (“Uniden”) apparently liable for a forfeiture in the amount of twenty-three thousand dollars
($23,000) for willful and repeated violation of Section 302(b) of the Communications Act of 1934, as
amended (“Act”) and Section 2.803(g) of the Commission’s Rules (“Rules”).
The noted apparent violations involve Uniden’s marketing of non-compliant General Mobile Radio Service (“GMRS”) transmitters.
  #33 (permalink)
Old 11-05-2009, 01:30 PM
KE4ZNR's Avatar
I hope you do realize that the info below has NOTHING to do with scanners. It has to do with GMRS radios which have nothing to do with this thread. If you are trying to harm Uniden's reputation you will have to try another way as this attempt fails.
Marshall KE4ZNR
from DA 09-2374
Marshall
@KE4ZNR on Twitter
  #34 (permalink)
Old 11-05-2009, 01:49 PM
Highpockets's Avatar
Marshall KE4ZNR
If Uniden did violate FCC regulations for whatever product they sell, it does harm their reputation I would say.
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
  #35 (permalink)
Old 11-05-2009, 01:55 PM
KE4ZNR's Avatar
I do agree about that however the post I am talking about appears to be nothing more than a strawman designed to try to smear Uniden's reputation.
Why would the poster post info about a GMRS Transceiver issue in a thread that has NOTHING TO DO WITH GMRS.
If you read over his post it actually makes no sense as he first talks about his 396T and rolling back firmware then makes an illogical jump to talking about GMRS transceivers. The 2 things have nothing to do with each other.
Let's get this thread back on the original topic of Moto Type II P25 reception in the 396XT.
Marshall KE4ZNR
Marshall
@KE4ZNR on Twitter
  #36 (permalink)
Old 11-06-2009, 04:18 PM
I would suggest that the OP post his file (either ARC-XT or preferably FreeScan) so that we can take a look at what's programmed. That would give us more info to possibly be of assistance.
Dick
WD9GRI
Milwaukee, WI
