Old 10-28-2009, 04:04 PM
Default bcd396xt usb-1 device
My laptop does not have a serial pot so I got the usb-1 cord.
The laptop will not recognize the connection. I have tried all the different
rates but nothing helps. I am using XP. What can I do?
Old 10-28-2009, 04:06 PM
W5JSS's Avatar
Did you install the driver?
Old 10-28-2009, 04:11 PM
Default usb device
yes i did install the driver from uniden.
Old 10-28-2009, 04:12 PM
Yes I did install the driver from Uniden.
Old 10-28-2009, 04:15 PM
check & make sure comport on software matches what is shown in windows
Old 10-28-2009, 04:36 PM
UPMan's Avatar
Uniden Product Manager
When you plug in the USB-1, if the drivers are installed properly the cable will be assigned to a COM port. To verify, click the START menu on your XP desktop, then click Control Panel, System, the Hardware tab, then the Device Manager button.
The cable will show up under "Ports (COM & LPT)". Make sure the port assigned to the cable is the one you selected in your software.
If it doesn't show up there, then the driver isn't installed.
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 10-30-2009, 12:43 PM
Unhappy bcd396xt usb-1 device
Yes the cable shows up on com5. But when I try to connect nothing is detected.
I have tried different com ports with no luck.
How can I be sure I have the correct driver for the bcd396xt?
Old 10-30-2009, 01:25 PM
UPMan's Avatar
There is no driver for the scanner. The driver is solely for the converter cable.
What software are you using?
Old 10-30-2009, 01:35 PM
make sure the comport shown in windows is the SAME 1 showing in the software
Old 10-30-2009, 01:39 PM
tmfok7's Avatar
One other possibility... if you plugged in the cable before you installed the software, it won't recognize the cable. If so, you will have to un-install the software and start over.
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
Old 10-30-2009, 01:50 PM
Arrow bcd396xt usb-1 device
I am using bothe Freescan and ARC XT PRO.
Also the scannewr does not show any comport just serial speeds.
Old 10-31-2009, 05:10 PM
davidmc36's Avatar
The reference to the comm port is not on your scanner, you need to check that your SOFTWARE and WINDOWS (ie Device Manager) are set to the same port.
No Bounce, No Play.
The one who dies with the most toys wins!
Personal Weather Station
Old 11-02-2009, 12:14 AM
Are you using a usb=1.0 cable from Uniden?
Old 11-04-2009, 01:58 PM
Unhappy usb-1 device
Yes the com port and software are set the same. I have tried all com ports with no results.
ARC_XT comes up with the message "No BCE396XT detected."
Old 11-04-2009, 04:56 PM
davidmc36's Avatar
This sounds like the most likely scenario to me then. Did you try, uninstall the USB adapter, restart the computer (with the adapter unplugged), reinstall the driver, restart the computer again, and then plug in the adapter.
No Bounce, No Play.
