Old 10-31-2009, 06:03 PM
kc0vgj's Avatar
Send a message via Yahoo to kc0vgj
Question Continuous Band Coverag Question?
Continuous Band Coverage Question? Why did the FCC Exclud UHF TV? Frequencies on scanners?
Old 10-31-2009, 06:09 PM
N_Jay's Avatar
The only band excluded by the FCC is the cellular portion of the 800 MHz band.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 10-31-2009, 06:49 PM
kc0vgj's Avatar
then why does my scanner the bcd396t skip 512mhz to 763mhz?
Old 10-31-2009, 07:19 PM
N_Jay's Avatar
Because Uniden designed it that way.
Old 10-31-2009, 08:21 PM
wlmr's Avatar
Just heard a Pa-dump-bump-CRASH from the drum section!
Old 11-01-2009, 12:13 AM
MarkWestin's Avatar
The BR330T includes the 512mhz to 763mhz frequency range. In addition to the former analog UHF TV audio, there are quite a few wireless microphones that operate in this frequency range.
KA1TIV
Old 11-01-2009, 02:12 PM
DaveNF2G's Avatar
Most scanners have excluded the UHF TV band since the first ones were made. There are no crystals AFAIK for that band, and until the upper portion (channels 69-83 or thereabouts) of the UHF TV band were reallocated few if any scanners would tune there. (470 to 512 used to be TV channels, too, which is why it is called "T-Band.")
The FCC had nothing to do with it. Scanner manufacturers have to balance consumer demand (as they perceive it - not always accurately) for frequency coverage with the technical difficulty (read: expense) of building a scanner that will do the job adequately. There has been no "need" for scanners to cover most of the UHF TV band until now, so scanners generally have not been designed to tune there.
The newest scanners cover the band, although the boundaries and capabilities within the 700 MHz band are variable among models.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 11-01-2009, 02:30 PM
kc0vgj's Avatar
thank you explaning to me this. The reason I asked is that in my manual it stated that cell and the T-band ar blocked and moddifing it will brake the law.
Old 11-02-2009, 07:44 PM
DaveNF2G's Avatar
Those are two separate issues.
The T-band would not be "blocked." It would simply be missing from the scanner's available frequency coverage.
The cellular bands are blocked by law. The radio's circuitry might be capable of receiving signals in that range, but the manufacturer is not permitted to allow that to happen. Modifying the scanner to override or bypass this block is illegal.
