Old 10-31-2009, 07:10 PM
Default Interference when scanning
I have a Uniden BC340CRS scanner. My scanner stops on alot of channels w/interference. I try to squelch it out, but it does not help. I have moved my scanner in different rooms in my house, still does not help. I installed an outdoor antenna, still the same problems. I notice it does alot more interference when my Dish Receiver & TV are on. Any suggestions would be appreciated. thanks for listening.
Old 10-31-2009, 09:07 PM
Tryton's Avatar
lockout the offending freqs?
Equipment : Uniden Bearcat BCD996XT
________________________________
K1SPL
Old 10-31-2009, 09:11 PM
Gets interference on the good frequencys that I listen to also.
Old 10-31-2009, 09:38 PM
DDan's Avatar
It's a little drastic but you could turn off the breakers to the house. Turn them off one at a time and see if the interferece stops. Once you isolate the breaker, you can start work on everything plugged into that circuit If you turn off all breakers to the house and the interference persists then it might be a neighbor. I have heard several stories about plasma TV at neighbors houses causing interference. .
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 10-31-2009, 11:56 PM
Post
You didn't mention how many channels but I try this when I have interference problems. Try the next frequency up or down and see if the interference goes away. It is usually not off far enough to interfere with reception. It will not always work and it would be a bit difficult for trunking frequencies I would imagine. I do it usually with aviation freq's and it works most of the time. Otherwise a very difficult problem to solve.
If all the world is a stage then where would you put the antenna?
