Old 11-01-2009, 05:41 AM
Default BC 895XLT Technical details? More than just the specs.
And - yes, its for the 895.
I need the "timing sequence" for a scan lock and "audio" out on the line jack.
Reason:
I will use the scanner as a dual channel AIS receiver, ( I know that a scan rate of 10 ms. is less than desirable).
I know about the discriminator tap, but by using it - I have to analyse a continous stream of 90% noise. (Terrible waste of computing power).
My idea is to use the taperecorder output which is activated when the scanner lock onto a chan.
I have 3 ms. available (the AIS training sequence + start block) so I need "tape output" < 3 ms. after carrier detect.
Can it be done?
