Old 11-04-2009, 03:47 PM
Default better portable antenna
im just wondering if anyone knows which is a better antenna for the bcd396t
the
800 MHz 2.5db Gain Professional Portable SMA Antenna from scaner master which i now have or the radio shack 800 mgh
Old 11-04-2009, 09:37 PM
Send a message via AIM to kb8rvp
I like the one from radioware book store Radioware & Radio Bookstore Radio Hobbyist Catalog the Seeker 800 to 900MHz Gain Duckie SEK800 $42.95 If you are at all in a weak area and want to use a rubber duck this is the one for me.
kb8rvp
Old 11-04-2009, 10:49 PM
WX4JCW's Avatar
Send a message via Skype™ to WX4JCW
I have both, i think both are about the same performance wise but the scannermaster one doesn't need any additional connectors.
Jason WX4JCW
TM-D710,ID-880H, HT60, BCD396XT
Retired Dispatcher-EMT
Rural Metro Ambulance Orange County Fire Rescue
Old 11-05-2009, 05:19 PM
Question bcd396t
is the seeker that much better for all bands .i need to find a good attenna i live in ct bad deadzones
Old 11-07-2009, 09:34 AM
I don't have the other antenna mentioned so all I can speak to is the seeker antenna and it is the only antenna that will work inside the two different office buildings I work at. If I try the stock antenna or the Radio Shack 800MHz antenna it won't pick up the 800MHz system I listen but the seeker will.
Good Luck,
kb8rvp
Old 11-07-2009, 10:51 AM
nosoup4u's Avatar
Send a message via AIM to nosoup4u Send a message via Yahoo to nosoup4u
The Seeker is also very good on VHF and UHF (Including T Band)
John - KC2KZZ
http://wc2em.net/scanner
http://kc2kzz.blogspot.com/
BCD396XT, BCD996T & BCT15
Saber II (VHF), HT1000 (UHF), Astro Saber III (800)
Old 11-07-2009, 08:25 PM
kayi4cle's Avatar
The Seeker antenna can't be beat, in my humble opinion. But I would not use it with a handheld radio (especially one of the smaller ones) because it is so large. Mine is 10 1/2 inches long, and the first 1 1/2 inches nearest the base is the same circumference as a dime. It is also on the heavy side and not very flexible. I attach mine to a BNC magmount and run it to mobile/base radios.
Old 11-07-2009, 08:58 PM
The Seeker is fine on a PSR-500 but it definitely puts the 396XT off balance,causing it to tip over very easily. I prefer the RS-800 with the 396XT. Uniden supplies the adapter you would need for that antenna. I wish one of the antenna manufacturers would make a SMA version of that antenna. Probably won't happen if GRE holds the patent on it.
GTO_04
Old 11-07-2009, 09:40 PM
Hi,
I'm using a Scanducky - SMA (from Mobile One here in Australia) with my Uniden BCD396T.
Can be fouund here; Mobile One Australia Pty Ltd
UHF VHF Helical 25MHz - 1300MHz 50 Ohms.
Awesome performance compared to the Uniden antenna (as supplied). Worth a look.
Cheers,
Paul.
Uniden Bearcat BCD200XLT - BCD396T - UBC RH96 Remote Head
Old 11-08-2009, 08:18 AM
PM08203's Avatar
pryme radio products rd-98 with sma connector.
Old 11-09-2009, 08:14 AM
Thumbs up thanks
thanks guys for the info
