K
kb0nly
Guest
Has anyone been able to make the tape/record out jack on this scanner a real line out, so that its not controlled and turned on and off?
The pause at the beginning of every transmission and the CHUNK noise is getting annoying on my feed. And don't say use the speaker jack, if i could i would, but i want to be able to still listen locally and turn the volume all the way down when i walk away.
Maybe take audio off before the volume control so its a constant level? Or does anyone know the component at which the scanner turns the audio on and off to the jack?
There has to be a way. If i had a damn schematic i could do it, but nobody has a service manual or schematic for it.
