Old 12-13-2010, 4:04 PM
Jethro32's Avatar
Default BCT15X Channel Tag
How do you tune directly to a channel using the channel tag thats programmed to it?
Old 12-13-2010, 4:36 PM
UPMan's Avatar
NumberTags < UnidenMan4 < TWiki
Uniden Product Ninja
Professional Scanner Developer
Old 12-13-2010, 4:45 PM
Jethro32's Avatar
Excellent. Thanks for the quick reply.
Im having an issue with control channel only scanning with the 15X. How do I turn it off? I have a 15 and an X and both are showing finding control channel. I programmed the 15 yesterday and it was working fine until today. I just programmed the X and I cant figure out how to turn off control channel only. Im using Proscan to program the scanners.
Old 12-13-2010, 5:00 PM
UPMan's Avatar
There is no other scanning mode for Motorola trunked systems. "Finding Control Channel" means that the scanner cannot receive a control channel on any of the frequencies programmed for the system.
Old 12-13-2010, 5:02 PM
Jethro32's Avatar
When I use proscan with the bct15 there is a check box for control only. On the 15X its not there. My 15 was working fine last night but now Im getting the finding control channel message. I was just programming the 15X for the first time when I got the same message on that one.
Old 12-13-2010, 5:04 PM
UPMan's Avatar
I would suspect that something has changed on the system (like they've moved to an undocumented alternate control channel or rebanded).
Without knowing which system, tough to make better guesses.
