Originally Posted by badchad112
Thanks guys! Finally, if you had a choice of getting a HP-1 new or BCD996T new, which would you choose?
I'm on the fence...
It would depend on how well you understand the Uniden DMA structure, or whether you are a bit of an electronics "nerd".
The "T" & "XT" series of scanners can do quite a few things, many of which the HP-1 cannot do. If you want to have a less complicated set-up, then HP-1 is the way to go.
I live in the Twin Cities, so I have a good idea of what you'll be able to listen to. I already have both the "T" & "XT" series units. From what I've heard, the HP-1 will have a bit better receive, so I'm personally excited to get my hands on the HomePatrol to see if this is the case. I know it will be easier to just listen straight out of the box.
MM
