Dewey
- Joined
- Dec 19, 2002
- Messages
- 1,026
Every once in a blue moon, I see comments here about getting louder external audio on the 396 T/XT by grounding the audio common to the antenna ground. While I have successfully done this on the GRE Pro series, I have always been very hesitant, hence never do this on the 396 for the following reason (actually I did try it once very quickly using a paperclip, but it only lowered the audio, not amplified it):
Top of page 6 of the BCD396T manual...
While I know this appears to be the standard "Lawyer Notice", it does include the warning that it may damage the scanner. I also know that there are some here who have reported to have operated the 396 with the mod without negative results.
My reason for asking at this time is because I would like to put this matter to rest in my mind. This site (RR) has included ads for the following speaker/mics (speaker only):
SpectrumForce Scanner Lapel Speaker BNC
SpectrumForce Scanner Lapel Speaker SMA
When you look at these speakers, the manufacturer reports getting the audio gain by performing the aforementioned shorting method. The manufacturer also reports that these speakers were made with the 396 in mind. What are the opinions of those here on these speakers with the ground mod? I could always buy one, and go in the speaker and cut the mod, but then I would risk low to inaudible audio on a product that I would not be able to return.
Thanks,
Dewey
Thanks,
Dewey
