I'm in Fulton county, about 20 miles west of Toledo, and I have the same problem. The Lucas county system is a simulcast system that appears to use the same frequencies throughout and I think that is my problem. If you pickup data streams from two different transmitters they will interfere with each other and cause dropouts. I'm hoping that, when Fulton county joins their system, the new transmitter at Wauseon will solve my problems.
