| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
07-07-2011, 1:26 PM
Service search BCD 396 XT
Help !!
I've turned on a Public Service search and for the life of me, I can not turn it off. The News and Public Safety are activated and I want to turn them off. Any help is greatly appreciated. I felll sooooooo stupid.
Thanks,...Ed
07-07-2011, 1:27 PM
F+L/O, L/O while in that search permanently locks it out.
07-08-2011, 3:45 PM
I tried that but did not work. Maybe I'll have to reset the radio??
07-08-2011, 4:05 PM
Anyone else notice UPMan's new avatar: "Extreme Makeover--Home Patrol-1 Edition"? Must be some kind of "hint" of things to come. I'd like to see one that reads: "BCD-396/996XT - Now with TDMA!"
07-08-2011, 4:22 PM
If that did not work...you missed doing something. So, I'll say it slightly differently.
While scanning, when the scanner is scanning the service search, press F (at that point, the scanner will temporarily hold on the service search; if it has moved on and is no longer on the service search, rotate scroll to bring the search up, again). While F is still active, press L/O twice within a second. This will permanently lockout the search.
You could also navigate the menu to the search settings and turn off Search with Scan for that search.
01-09-2013, 3:07 PM
I'm having this issue too.
Both "Public Safety" and "Custom 10" are showing up when I manually click through the select knob on top. The two systems are locked out of searching, but they're still manually accessible and there's a ton of them I'd like to remove.
In Freescan under "Set Scanner Options" then "Service Search," I've disabled everything under "Search Key Assignments."
Uploading those settings, those two systems still show up in my search. There's gotta be another option to set somewhere.
01-09-2013, 3:19 PM
Disable Search
Freescan: On "Custom Search" tab, lockout the whole column.
~Doctor Dialtone
BCD996XT, BCD396XT, PRO 2004 Modified, BC2500XLT Modified, Minitor V
This post is worth another 4 RR points towards free trips and other valuable discounts!
01-09-2013, 3:28 PM
You cannot delete service searches or custom searches. You can only enable/disable (or lock/unlock) them.
01-09-2013, 3:54 PM
If you use software to program the radio (I can only speak for Proscan), assign each of the service searches a Quick Key. That allows fast 3 keypresses to turn them on or off. I couldn't find a QK assignment option via menu but the software had it.
chris
01-09-2013, 4:44 PM
That's how I have it set up. Every one from Custom 1 to Custom 10 is individually locked out. I don't see an option for "Public Safety" there.
01-09-2013, 7:13 PM
Public Safety
chris
Try this:
Menu->Search For....->Edit Service->Public Safety->Search With Scan->Set Quick Key or Set Lockout and take it from there, or see the attached.
If you need to, assign an unused Quick Key 0~99 (99 in my example)and disable the QK ".99"
I haven't recreated it, but I'm sure that you're very close to a solution.
Good luck!
~Doctor Dialtone
