Looks like some people have this same issue but here goes anyways...
freescan used to import all frequencies... used quickkeys and set all ctcss to search as that is all thats used within our county... worked great for 2 months with RS discone ant. rubber duckie always sucked... had just about full signal strength for all i was scanning with ATT on... now with ATT on or off recption is poor and only 1 signal strength bar.. thought it was antenna so i connected my rs pro 197 and signal is fine so im wondering if this is a problem with the 396xt or if maybe its interference from the several pager frequencies within 800 ft of my house.... also am across the street from local volunteer fire co and about 1/4 mile from the main fire and ems paging tower for out area... So i guess my question being new to Uniden SCANNERS is will intermodulation stop or reduce the signlas that have always been full strength even with the anntenuator on or off... also new cell tower just was built here about 1/2 mile from home and isnt activated but some testing is going on... is there any possibilities the cell tower or pager frequencies would fry the front end of scanner or would it be something else... i always have it OFF during storms and what not.... or do you think its just to sensitive of a scanner for this area and adding an external antennuator will cure the issue...
please any suggestions on what can help save a 480.00 scanner from this happening again would be much appreciated... thanks in advance
