Old 10-11-2005, 08:49 AM
Smile Uniden 396T Silkscreen repair time
Just thought I would pass this along:
October 3 - Unit shipped to Uniden
October 5 - Unit received by Uniden
October 7 - Unit sent out unit by FedEx per Uniden email.
October 11 - Unit to be received by me (per FedEx website).
Not bad I don't think! I hesitated because of some of the stories on this site and had planned for at least a one month downtime.
jpjohn
Old 10-11-2005, 09:40 AM
rhutch's Avatar
Send a message via MSN to rhutch Send a message via Yahoo to rhutch
I hope it works out for you.
Sent mine August 29th
was suppose to be delivered Oct. 3
Still waiting.
Old 10-11-2005, 03:13 PM
rhutch's Avatar
It's here, it's here. It's been gone so long I have to go back to the manual to learn how to use it again.
August 29 until October 11 not bad for a 5 day fix
Old 10-11-2005, 05:01 PM
John_M's Avatar
Rhutch: Glad you finally got yours back I received mine back today 10/11 as well. I sent mine in 9/26 so it took 16 days.
John.
Old 10-11-2005, 08:04 PM
avistow's Avatar
Talking
1 - Attach Scanner to Computer
2 - Open UASD program
3 - Select Configuration Name
4 - Click on Write to Scanner
I could not imagine having to program it without the Computer!!
Old 10-12-2005, 12:22 PM
kinekep's Avatar
ARTCC DB Manager
I sure hope that I have the same luck with the quick turnaround for the silkscreen issue. Mine gets shipped off tomorrow for faceplate replacement. A quick question though.... I have read that Uniden is replacing the speakers in the units as well. Should I expect this to be done to my unit also since it will be there, or should I just expect the faceplate to be replaced?
Paul
N3WYY
RadioReference.com ARTCC Database Admin BR330T/PRO162/PRO137/PRO433/BC350A
Airnav Radarbox 2010
Old 10-12-2005, 06:57 PM
I haven't had time to play with it yet, but I noticed on the shipping ticket that two parts were replaced. Maybe the speaker and the face plate???? Battery cover looks the same.
I will play with it tonight and see if it sounds better.
jpjohn
Old 10-12-2005, 08:19 PM
I have no way to be scientific about it, but it does seem that it is cleaner sounding and louder. But that maybe is just because I was without it for a couple days!!
jpjohn
Old 10-13-2005, 07:29 AM
kinekep's Avatar
ARTCC DB Manager
Thanks! I will soon know what you mean!!! Anyways, I kinda figured that maybe the techs at Uniden would check the speaker as well while it's there to prevent a return visit for servicing.
Paul
N3WYY
Old 10-13-2005, 05:19 PM
Al42's Avatar
Since the speaker is glued to the front half of the case, if they replace the front half of the case, they probably replace it with one that has a speaker in it. Paul mentioned the difficulty in getting the speaker out of the old case and I doubt they'd want to spend the money (tech's time=tech's salary) to save a speaker that probably costs less than a buck.
Suffolk County, NY PD live stream
and the files you'll need to do it yourself: http://www.webdingers.com/scanner.html
Winamp connection: suffolkscanner.redirectme.net:8000/stream
