Originally Posted by RoninJoliet
If your trying to set up priority channels in a trunking "SYSTEM" by hand you need to go to the "SYSTEM" in question, go into the "MENU" options and turn "ON" "Pri", then go and turn "ON" "Pri" on any TG's and it will work....
Ron has it correct.
From a long ago post of mine found in a forum search:
The info below describes how to understand the differences between Conventional Priority
and Trunked Priority ID Scanning. If you are seeing the "Priority Scan, No Channel" message that
has to deal with conventional priority ONLY and not trunked priority ID scan. It means that you are trying to activate conventional priority on a system that has no conventional frequencies assigned as priority. It has nothing to do with Trunked Priority ID Scanning.
If you are seeing the "Priority Scan no Channel" message that means that you have tried to use the Conventional Priority Feature instead of the Trunked Priority ID Scan Feature. It is easy to get the 2 confused but if you do the following Priority ID will be turned on:
1)Navigate to the system
2) Select "Edit Sys Option"
3) Select "Priority ID Scan"
4) Select "On".
5) Navigate to Talkgroup you want set as Priority.
6) Select "Set Priority" to "On".
This should get you squared away.
Happy Monitoring
Marshall KE4ZNR
