Originally Posted by Asmitty0010
Wondering if you can do this:
I want to use a BC-RH96 via the front jack of a 996 and also be able to send the tags to my computer via the rear data jack of the 996.
Can both ports be used at the same time or do I need to choose either sending tags for my feed or having a remote head?
thanks.
Yes, the front and rear ports can function simultaneous. Using the rear port, a null modem adapter is needed which is nothing more then reversing pins 2 & 3.
[EDIT] I should note that they both work simultaneous for sending text tags. Don't know about the BC-RH96.
