Old 01-12-2012, 7:02 PM
Exclamation cross talk ,, bleed over
On both my BCD996XT and BCD396XT, I am getting cross talk from other talk groups. It is not a once in a while thing, it is happening a lot.
The system I listen to is Montgomery County Maryland Public safety.
It happens when scanning and when locked on a talk group.
Am I alone here or is this happening to you to?
Any thoughts on what may it be may be?
Old 01-12-2012, 7:08 PM
DDan's Avatar
Check your endcode setting.
73 de W6KRU - Dan
BCD396XT BCD396T PSR-500 FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
RS 20-176 | Maxrad MFB8133 MYA8256 MUF8043 MLB3400
Old 01-12-2012, 8:16 PM
scanningisfun's Avatar
Send a message via MSN to scanningisfun
It is probably hung on a voice channel. As DDan said, try enabling the encode settings which will make the scanner recognize the terminator data unit. Change it to Analog+Digital.
Old 01-14-2012, 2:07 PM
Ok, here is the scoop, I have had digital scanners for years and I have never set the end codes to anything other than ignore. I have never had cross talk like this before.
That being said, I set the End code on the 996xt to ANALOG+DIGITAL and left the 396xt to ignore.
DDan, you hit it dead on the head. the base no longer has the cross talk and the portable still thinks its broken. (I will reset the 396)
DDan, Thank you.
Scanningisfun, thank you too.
Old 01-14-2012, 2:16 PM
DDan's Avatar
You are welcome. I'm glad I could help.
73 de W6KRU - Dan
