Old 04-23-2012, 6:13 AM
DavidQT69's Avatar
Send a message via ICQ to DavidQT69 Send a message via Skype™ to DavidQT69
Question BCT-15X unit ID feature...
I have a question: I have the Unit ID feature properly displaying the UID's for my trunked systems, however for my conventional VHF channels they aren't displaying. My agency and surrounding agencies all have UID's for their portable radios and such so common sense tells me if my scanner displays UID's for a trunked system then it should display for a conventional system too, am I doing something wrong or is displaying UID's for a VHF or UHF channel not possible?
-- David C.
Lincoln County, NC feed provider
IPN Hotline Dispatcher, FLA-294
Old 04-23-2012, 6:18 AM
lep's Avatar
lep lep is offline
Smile
UID only displays on trunked systems. It appears you scanner is working normally,.
Old 04-23-2012, 6:25 AM
DavidQT69's Avatar
Thumbs up Re: UID's
Hmmm, strange... I wonder why it will display on trunked systems but not conventional systems... Thx for the quick reply...
-- David C.
Old 04-23-2012, 1:06 PM
DJ88's Avatar
Send a message via AIM to DJ88
I wonder why Uniden does a lot of things they do.
My Toys:
Uniden BCT15X | Uniden BCD996T | Uniden BCD396T
Uniden BC785D | Bearcat 210XLT
Old 04-23-2012, 2:07 PM
lep's Avatar
lep lep is offline
Smile
I don't claim special knowledge of the subject however: this has nothing specific to do with Uniden. GRE and RS scanners behave exactly the same way. UID is a function of Trunking Systems, decoding was formerly only an add-on sofware packages like Unitrunker and required a hardware MOD to the radio to bring out an access point for the decoder
It has only been since aroud 2010 or so that scanners were designed with the needed decoding built-in. In many cases some late model scanners could add this feature by updating the firmware.
Old 04-23-2012, 2:55 PM
druhe's Avatar
When you say conventional, do you mean analog ? If it's analog and you are referring to the "squawk" at the beginning or end of the transmission, it's more than likely MDC. At the present time there is no scanner capable of decoding it. MDC has been around for a long time, I never understood why it's not a feature.
--Dan-- KE3UC
Old 04-27-2012, 3:33 PM
lep's Avatar
lep lep is offline
The display of UID in trunking systems is not a function of whether it is a digital or an analog system, UID works the same in both.
Old 04-27-2012, 4:34 PM
scanningisfun's Avatar
Send a message via MSN to scanningisfun
If it is MDC1200, you can download the program at the link I will post by clicking download in the sidebar. You can to hook your scanner with or without a tap. It will decode the MDC1200 IDs.
antistatic.org - winmdcd
Jacob
Tags
bct15x, uid, unit ids
