Old 06-24-2012, 4:54 PM
owenmcc1's Avatar
Question BCT15 problem/question
I recently purchased a used BCT15, and already it appears I may have a problem. But rather than jump to conclusions, I thought I'd check and see if anyone else has had the same problem.
When it stops on one of the channels I have programmed in, it acts like it loses signal right in the middle of transmission for about 2-3 seconds, and then it comes back. I've never had this on my handheld BC250D or my old PRO-99. Has anyone else encountered this?
Owen C. McCormick
Production Assistant
KWPC/KMCS Radio
Muscatine, Iowa USA
Old 06-24-2012, 4:58 PM
Wiki Admin Emeritus
Perhaps a conventional priority or Close Call priority is turned on...see the 2nd question of...
DMA P25 Decoding and Audio Issues - The RadioReference Wiki
from our DMA FAQ
Old 06-25-2012, 1:06 AM
owenmcc1's Avatar
I shut the WX Alt Priority off and that did the trick. That hadn't even crossed my mind. Thanks!
Owen C. McCormick
KWPC/KMCS Radio
Muscatine, Iowa USA
Tags
bct15, illinois, iowa, problem, uniden
