| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
07-15-2012, 12:05 PM
Yes fyrfyter10, I've selected all of the services I was interested in, but no joy. Thanks for the suggestion anyway.
Bob
07-15-2012, 1:03 PM
junk
My hp is doing the same almost like their are no freqs.in the unit and since I have nix computer,can't check it out!I had a friend his was also getting nought,found out it fell off the dash once and hit the antenna.There was a tiny piece of the copper wire broken off in the connection.He pulled it out and put on a newbie duckie and now at least his works.
I have been into the hobby since 1964,still have my very first radio thats works great.It is a KNIGHT 30-50MHZ,TUNEABLE that uses Vacum Tubes.I am very frushtrated over this uniden piece of crap,looking at the GSR.GOOD LUCK & GOD BLESS hope everything works out.
07-15-2012, 11:45 PM
Originally Posted by kruser
So did it work ok when they sent it back even though they said they found nothing wrong with it?
Nope, it was still deaf as a rock. My Pro-106 and PSR-500's were more sensitive without an antenna than the HP-1 was with a good aftermarket antenna on it. Off it went. I was going to send it off to Uniden again, but I have had enough bad dealings with Uniden's repair service in the past that I just decided to let it go and chalk it up as a lesson learned. I sold it to a guy for a cheap price and he's happy with it, judging by his emails.
Pro-2004, 2005, 96, 106, 197, PSR 500. Kenwood R1000, TS-850SAT. JRC NRD-525, Allied SX 190 (2, one works 100%), Yaesu FRG-7(2), Hammarlund HQ-100, Icom R71A (2), a few old CBs.
07-17-2012, 3:39 PM
I agree - I have really been disappointed with the HP-1 problems. I have been running my PSR-800 instead and it has given me renewed appreciation for how good that radio is (and my Pro-106). I hope I can get the HP-1 running without repair or return to the seller, but I am not feeling too hopeful. Too bad, great concept, crappy execution.
07-17-2012, 5:22 PM
Bkantor have you talked to anyone directly that can maybe help you I did send you a pm but no responce from you. Or maybe you just want to not try to find the problem.
Doug: Even when you are right, you are wrong. Go figure.
Pro-38 - Pro-2006 - Pro-2020 - HomePatrol 1E and a HP 1 Can you hear me now?
07-17-2012, 5:50 PM
I spent many years as a two-way radio tech and the symptoms you describe sound like either a faulty connection between antenna and circuit board or a fried RF amplifier in the receiver. This can easily occur even by keying a 5 watt hand-held radio within several feet or the scanner. If you know of anybody who does 2-way radio work in your area, ask if they will throw a service monitor on that Uniden and measure it's actual sensitivity.
07-17-2012, 7:43 PM
I have been corresponding with the seller - and I do want to find the problem, but I work alot of hours and didn't want to disturb you at late hours. I appreciate the offer to walk me through the problems, but as I said, I have been unavailable.
Bob
07-17-2012, 10:55 PM
I bought an HP-1 brand new about a month ago. The first thing I discovered was that the antenna that comes with it is about useless, especially since I live in a very rural area...in connecting an exterior antenna, the ground shield absolutely must be 100% grounded properly to the SMA connector or you won't recieve anything...I am with Arwolf, the most common problem is antenna connection. As I am also a HAM who builds his own antennas, I can tell you that antenna impedance and grounding make all the difference in the world. If you can't get at least a 5 by 9 signal for NOAA weather radio, you are not receiving from your antenna at all. It is a good sign that you receive that nearby EMT traffic, it means that the discriminator is still functioning and receiving on the stub on the circuit board. I hope you used paypal...send it back and get your money back.
Sgt. (Ret) Kevin Heyboer
Amateur Radio Call: KD4UYR
Active HAM since 1993
07-18-2012, 8:31 AM
Thanks - you have provided very useful information - I couldn't understand why I was not receiving NOAA, yet there was some EMT traffic! I did purchase through Paypal (via BillMeLater), and am working with the seller to return the unit. He is going to fire it up when he receives it and is going to shoot a video opening the box to either prove me right or wrong before refunding my $$.
07-21-2012, 9:42 AM
Follow up
Just installed an old duckie from my old BC-100xlt,and the HP-1 is working like gangbusters,finally.I am still not really happy with uniden.Bearcat/uniden or just bearcat were great.I have a bearcat 3,4,760,210,220,250,300,800 no blocks,890 awsome no blocks 29mhz-996?mhz,and 260 and of course the ole Jolly Roger.Glad you rid yourself of an apparant problem child.Due to health conditions of chronic/terminal I need to get rid of my collection.Out of 45 radios,still have 21 left,plus some FREE surprises,like a mint Radio Shack 160 S/W .God Bless to all!!
