While in SCAN mode you'll see the "S0: *234*56*---" on the second line from the bottom.
(That's how mine is organized, 1 for Priority system (if a cruiser goes by code 3 and I've not heard anything yet i'll quickly deassign the other systems leaving system 1 the only one to scan to speed capture of who's doing what; 2 for assorted freqs I've picked up in the area like buisness freqs, RTA's freq etc. 3 for county-wide freqs, 4 for city freqs like the one I'm in and neighboring, 5 for Qck Sav Conv Sys, 6 for CA Hwy Patrol and 7 for Natiowide).
"-" means unnassigned, "*" means turned off, and when the "x" number flashes, that's the system it's scanning ATM. To use double digit quick keys, press ( . no ) and you'll see the "S0" flash. Press 1 for instance, and it will switch to the "1x" systems and show any activated or inactive quick keys. To activate/deactivate a quick key of 57, you'd press (.no), then 5 (which switches to the 50 series system quick keys) then for a "suffix" if you will of system. For groups inside systems, while scanning in the chosen system, press and hold Func and the group keys can be turned on or off.
