Old 10-06-2012, 3:40 PM
cknizeski's Avatar
Default Remote Heag disconnecting
I had a BC-RH96 remote head laying around and decided to put it in my vehicle. I attached my BCD396XT to it and the RH96 will will keep connecting and unconnecting. After some trouble shooting I found it only does this while scanning, with the antenna connected. I have an external antenna that I use with the Home patrol and never had a problem with the antenna. I hooked up the rubber duckie antenna, as soon as I do it will disconnect from the remote head. If I am in the menu mode, it will stay connected. It seems to only disconnect while scanning with an antenna connected. I hooked in a BC346XT with the external antenna and it connects to the remote head with no problem. I also tried changing the baud settings, no change. Any ideas what is going on?
Old 10-06-2012, 6:03 PM
nosoup4u's Avatar
Look at your settings and make sure the control channel output isn't on extended. That would cause that to happen
John - KC2KZZ
http://www.warrenskywarn.org
PSR-800, BCD996XT (w/GPS) Home Patrol-1 & BCT15
Icom IC-80AD
Old 10-06-2012, 6:18 PM
cknizeski's Avatar
Wow! I would never have thought of that, but does make sense. It was turned on. Turned it off and works. Thanks a lot for the help.
