| Uniden Scanners A forum for the discussion of all Uniden scanning radios and receivers. |
11-08-2012, 10:52 AM
uniden close call help
how many channels can you setup for close call
Radio Shack Pro-94,Pro-197,Pro-2018,Pro-2044 / Win500
Uniden BC355N / Regency ACT-R-106 / Antenna Craft ST-2
11-08-2012, 3:57 PM
There are no channels for close call. Usually, the default setting is to scan all bands, but could tell it to skip 800, for example, if you know there are no 800mHz systems in the area. When it finds some signal, it will save the frequency in a system called close call, and it will do this for as many different signals as it finds. There are many other options for notification, depending your model.
Regards,
Clint Chamberlin
Luzerne County, PA
11-08-2012, 4:06 PM
Close Call tunes the radio to a strong signal.
You do not program any frequencies for close call, although you can 'block' some frequency ranges.
It needs to be stronger than all other nearby signals.
Easier to Read BCD996XT Digital Scanner Manual
Here's what happens with a very strong signal and 20+ scanners set to alert on close call hits.
Uniden CC DND - YouTube
Rich
11-08-2012, 4:26 PM
i have a bc355n this is my first uniden i have some radioshack models that has priority channels i like to set fire & ems channels to scan more than the police i didn't know if close call does that
11-08-2012, 7:35 PM
Close Call does not do that. However, your model also has priority, and it works the same basic way as your radio shack. Read the manual on Priority
Regards,
Clint Chamberlin
Luzerne County, PA
11-08-2012, 7:49 PM
i have seen where it has close call priority is that it
11-08-2012, 9:09 PM
Close Call
No close call Priority has to do with Close Call, you want to go through your menu and set PRIORITY.
Steve
Uniden BC396T Scanner, ARC396TPRO Software
11-09-2012, 8:04 PM
i can't seem to find that in the manual
11-10-2012, 7:54 AM
Neither can I. I searched the online manual for Priority, and all I found was CC. I have never heard of ANY Uniden without channel priority, so maybe UPman will clarify
Regards,
Clint Chamberlin
Luzerne County, PA
11-10-2012, 8:28 AM
Wrong model.
11-10-2012, 12:23 PM
do you think they have changed it to close call priority on the bc355n model
11-10-2012, 7:31 PM
No. As we have all said, they are totally different.
Regards,
Clint Chamberlin
Luzerne County, PA
