Old 11-14-2012, 5:39 PM
captncarp's Avatar
Send a message via MSN to captncarp Send a message via Yahoo to captncarp
Default BC346XT Clonning Error
Tried to clone two BC346XT using the included cabes plugged together with a DB-9 male-male connector.
When I hit Scan on the Master scanner it searches for a moment and displays ERROR on the Master.
They both say they are Version 1.05.00.
Any ideas what I'm doing wrong?
Old 11-15-2012, 1:29 AM
davidmc36's Avatar
Do you have a null modem in there?
Scanner Master Blog: Scanner 101 - Cloning Uniden XT Scanners
No Bounce, No Play.
The one who dies with the most toys wins
Old 11-15-2012, 4:21 AM
Wiki Admin Emeritus
A better solution - and free, too, as long as you have a USB cable - would be to dump one scanner's contents into software like FreeScan, then upload to the second scanner. Instant clone, with a backup to boot
Old 11-15-2012, 1:59 PM
captncarp's Avatar
Yes I did use a male to male gender changer I bought from Scannermaster.
I don't no why everthing with Uniden scanners is such a hassle. I have cloned and upgraded lot of GRE scanners with no problem at all.
I'm not going to load everything from one scanner into a PC and then down loaded to a scanner. IF I do what Uniden says is suppose to work for WIRED CLONING then I expect it to work. WITH UNIDEN IT DOESN'T.
So back to GRE I GO!
Old 11-15-2012, 2:14 PM
KevinC's Avatar
Moderator
Do you both the gender changer AND the null modem adapter?
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
Old 11-15-2012, 4:16 PM
captncarp's Avatar
That worked. Thank you.
Too bad Uniden couldn't say that in there instructions for Wired Cloning.
Old 11-15-2012, 6:41 PM
KevinC's Avatar
Moderator
Glad you got it going.
BC-210XLT
