Old 12-05-2012, 2:55 PM
lost_in_maine's Avatar
Default HomePatrol-Conventional Discovery Problem
Yesterday I did the Extreme Update for the HP1
Ran Conventional Discovery first time...found a few new hits with Tones listed in the results...
Today I tried a different search range, and is no longer showing PL/Tones in the hits...
Not sure if I disabled or changed something...
tried different search ranges, and no tones...
What should I check?
Doug
Uniden HP-1 Extreme
BCD-396XT - BCD-396T - PRO-96 - BC9000XLT
ScanTenna - Diamond Discone - Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
Old 12-06-2012, 4:00 PM
Question
Nobody has a clue?
Uniden HP-1 Extreme
Old 12-06-2012, 4:14 PM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
Maybe the other radios your hearing don't have a PL?
Sent from my iPhone 5 using Tapatalk
(402) 937-8578
Old 12-06-2012, 4:28 PM
No, not the case..
Here in Maine, some of the county's use the same frequency with 6-7 different pl's
And a few that are not in the DB..It was showing them
I could see if it was something in the RR DB already, then it wouldn't display, but was displaying some new hits that it found before with Tone, then now...everything says none for tone in the Run Results....
Uniden HP-1 Extreme
