Old 12-05-2012, 11:05 PM
Question HP-1 external power behavior
I'm thinking about getting a new scanner to permanently install in my car, and am leaning towards the HP-1 currently (mainly for replay and form factor/size). One concern of mine is how the HP-1 reacts when external power is added/removed, with batteries installed. Is it possible to configure it to power on/off automatically when the external power state changes?
I understand from the documentation and some research that without batteries any features depending on the SD card (such as replay) will not be available to prevent corruption, so I would prefer to operate with batteries installed to retain those features.
Old 12-06-2012, 8:10 AM
KD8HE's Avatar
You do have to manually turn it on and off. Unit will stay on when the external power is removed. If you cycle external power you will get a "charge batteries?" message which requires a response. I run mobile and leave it powered all of the time.
Harry
Old 12-06-2012, 8:33 AM
I decided that power control was more important than recording, and have my HP1 on ignition sense. Since the darn thing is smart enough to ask charge/no charge, you would think there could be an option for auto power control even though batteries are installed.
Old 12-06-2012, 8:57 AM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
I have a 996xt permanently installed and hard wired to my Ignition. It comes with a AC, DC, and hard wire.
I don't think I could leave my HP installed all the time.
Sent from my iPhone 5 using Tapatalk
(402) 937-8578
Old 12-06-2012, 9:28 AM
Thanks all. I figured it would probably require some manual intervention to turn it on/off, but was hoping to be wrong. I hate to give up recording to get automatic power control, but it may come down to that.
The HP-1 still has me on the form factor though - just no room to mount a 996xt or similar without some significant modifications to the dash pocket (too shallow, too narrow at the back). I already have a proclip mount to hang my 396xt, which will be easy enough to swap out for the HP mount.
@Kingmobileaudio: I'm curious as to why you couldn't leave your HP installed. Because of the power issue or otherwise?
Old 12-06-2012, 9:38 AM
For me it don't feel practical for it to be Permanent like my 996xt is.
But I can see me using the HP with GPS for traveling
(402) 937-8578
Old 12-06-2012, 3:42 PM
Here is my 996xt I have installed. It has 3 wires. Red is to Ignition. Orange is to Dash Lights. Black to ground.
When I turn on my head lights the scanner dims to the lowest setting. This is optional
(402) 937-8578
Old 12-06-2012, 3:52 PM
Redneck0410's Avatar
What kind of console is that and what kind of vehicle's it in? I doubt something like that will fit for my Blazer, but that'd be perfect for what I need.
I DO support Broadcastify! My feed can be found at http://www.broadcastify.com/listen/feed/12468
Old 12-06-2012, 4:01 PM
In a Ranger
Jotto Desk short stack
(402) 937-8578
Old 12-06-2012, 4:05 PM
lost_in_maine's Avatar
Looks like probably a Ford Taurus or Crown Vic with the ashtray removed...those are Ford Heat Control knobs in the pic..nice setup..
Uniden HP-1 Extreme
BCD-396XT - BCD-396T - PRO-96 - BC9000XLT
ScanTenna - Diamond Discone - Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
Old 12-06-2012, 4:10 PM
Thank you for the complement.
It also is blot right to the floor.
(402) 937-8578
Old 12-06-2012, 10:30 PM
What's the part number for the bracket for the 996? The one I tried was too big. Does yours fit snug or give you any install problems? I have a Jotto in my CVPI.
Also OT but do you like the SmartSiren? Can't decide that or a Cencom...
Old 12-06-2012, 10:40 PM
I love my SSP. Valor plugs right in to it.
Just wish they made a Smart Touchmaster Delta.
Looking at there website it shows 425-6095
I think that is the faceplate I am using. I just went to a local shop and told them I needed a faceplate for my 996xt.
(402) 937-8578
Old 12-07-2012, 1:04 AM
A site I went to after searching that one actually recommended another number. This is why I ask, I can't seem to get a straight answer.
Old 12-07-2012, 7:46 AM
Only thing I can think is to order the one if its not it have them swap it for the other one right away.
The numbers I gave. In the photo they show it as on there site looks just like the one I have.
(402) 937-8578
