Old 12-10-2012, 7:27 PM
Default Bct2
I have a bct2 circa 1980's that I was thinking of installing in my car. Now I know I can't monitor much since its a pre programmed scanner and its also not digital. But I'm curious as to with narrow banding if I can still monitor analog police frequencies with this radio
Sent from my iPhone yes iPhone using Tapatalk app thingy
Connor - WQND300
Old 12-10-2012, 8:17 PM
Redneck0410's Avatar
Some, probably. The audio will be a little less than what it normally is, since it's a little off the frequency it's used to scanning.
I DO support Broadcastify! My feed can be found at http://www.broadcastify.com/listen/feed/12468
Old 12-10-2012, 8:22 PM
Thanks. What's the best list of frequencies to monitor? Last time It was used it was set to ca. Is some other states programmed list better?
Connor - WQND300
Old 12-10-2012, 11:44 PM
W8RMH's Avatar
Remember that the pre-programmed frequencies are circa 1980s too, and have probably changed.
I don't think there are too many agencies operating with the same systems they had back in the 1980s.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 12-11-2012, 12:36 AM
That is true however the system I want to monitor is still analog so I'm hoping it will still work
Connor - WQND300
