Old 12-26-2012, 5:44 PM
AdamDaMan's Avatar
Default Another BCT15X question
Ok so I have been playing around on the scanner and I just noticed the signal on all my channels cuts out ever second or so and only pick up certain audio. Why is this? I am using the stock antenna for now but it will be hooked up to my nmo mount in my car here shortly. Any ideas on what this is?
Old 12-26-2012, 6:03 PM
Wiki Admin Emeritus
The most common things that can cause this is having Beartracker on, or it's one of the priorities (Close Call, Weather or conventional).
DMA P25 Decoding and Audio Issues - The RadioReference Wiki
It's kinda hard to diagnose how this happened since we don't know what software you're using, but undoubtedly there are settings there that can disable all of this...
HTH...Mike
Old 12-26-2012, 6:08 PM
Wiki Admin Emeritus
These 2 references should be kept handy - it's likely they will answer many of whatever other operational type questions you may have (anything blue is a link)
Uniden DMA FAQ - The RadioReference Wiki
Easier to Read BCT15-X Scanner Manual
HTH....Mike
Old 12-26-2012, 6:20 PM
AdamDaMan's Avatar
Thanks for the replies. Having close call on was the problem! Thanks!!
