Originally Posted by kbehning
In the short term, I'd suggest listening at 1:59 or prior.
I've never noticed this because I am usually in work at 2PM and in bed at 2AM.
I'm off for a few days, so I just might try this tonight. I'm setting my alarm for 1:30AM - long enough to remote start the pickup so it's warmed up just enough to go out there in my bath robe. It's 22 degrees! I got a little problem lately with the exhaust, so I hope my 6 neighbors here in the park aren't disturbed. It's a Full Moon, so I can tip toe out there without a flashlight.
Actually, I use one of those Black and Decker battery booster jump start boxes to provide a steady and constant 12 to 13.8 power source to the scanner. One double-ended cigarette lighter cable with a three-fer cable to power the scanner and run other things. It allows me to continue to run the scanner and other stuff when the key is off.
Sure, I may go up in a ball of flames some day, but everything will be fully charged for my descendants.
In answer to the OP - yeah - does it do this on the adapter? There might be some remnants of Pall Mall non-filter in the cigarette lighter thingie.
Good luck!
