Originally Posted by JoeyC
and the Enable I-Call checkbox checked on the Trunked System Setup page?
That doesn't apply to the XT series. As long as i0 (.0) is programmed, it will receive iCalls in ID Scan mode. The XT series will receive iCalls automatically in ID Search mode, as long as i0 (.0) isn't programmed and locked out.
Tryton, make sure you haven't locked out i0 in the system lockouts. I don't mean the one you programmed, but check the ID lockout lists.
Menu > Program System > Pinellas County > Edit Sys Option > Rvw ID:Srch L/O
