If you use AFS talkgroups mode, it doesn't work on wildcard talkgroups. That is, if you have 01---- instead of 01-011, it will work on the 01-011 talkgroup but not the 01---- talkgroup. At least, it doesn't on my BC346XT when monitoring my county's EDACS trunked system. To get it to work, you must enter each talkgroup separately (01-011, 01-012, etc) and not as 01----, 02----, etc. and then adjust each talkgroup as needed. Like I said, on my BC346XT it works like that....don't know about any other BC346XT. I hope this helps.
Nick, KF4SEK
RadioShack PRO-106, GRE PSR-310, Uniden BC346XT, ICOM ID-880H, ICOM IC-91AD, M/A-Com M-RK II Scan, Wouxun KG-UV3D, ICOM IC-80AD, Internet Labs DVDongle & DVAP Dongle, BAOFENG UV-5R
