Closed Thread
  #101 (permalink)
Old 03-07-2013, 4:10 PM
SquierStrat's Avatar
then also, disregard
GRE PSR-500, Uniden BCD396XT, Uniden BC350A, Uniden BC700A, RS Pro-83, (3) Motorola JT1000
  #102 (permalink)
Old 03-07-2013, 4:38 PM
bear780ks's Avatar
@ S.S. i was going to suggest something but decided to pull my post but being as is No Option for deleting Post which is wrong). I wrote Disregard sorry for the Misunderstanding
  #103 (permalink)
Old 03-07-2013, 5:35 PM
lol, yes, i saw that, and replied to it. then also had to pull my post. i too wish this site allowed post deleting
  #104 (permalink)
Old 03-07-2013, 5:51 PM
bear780ks's Avatar
Well of the 4 other Forums i have Visited in the past way in the past lol and the Verizon Forum which i'm a Senior / Platinum Contributor they all have had the Delete Option i don't know if it's from not being hi enough up the Ladder or as i was Told on seeing Advertisement in the thread i'm not a Premium Subscriber ?
I guess we'll both find out in do time Ra hope your issue's are solved soon on your Scanner..
  #105 (permalink)
Old 03-07-2013, 6:39 PM
RonnieUSA's Avatar
There is NO delete button for Premium Subscribers.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
  #106 (permalink)
Old 03-07-2013, 7:45 PM
bear780ks's Avatar
Ok that solves that). thanks Ronnie
This is what i read and found in the Rules & Regulations:
If you have registered and are logged in, you may be able to edit and delete your posts (although the administrator may have turned off this option). Your ability to edit your posts may be time-limited, depending on how the administrator has set up the forum.
To edit or delete your posts, click the Edit button by the particular post. If your post was the first in the thread, then deleting it may remove the entire thread.
So apparently this option is Available as it's shows in the Site Rules what i'm wondering is at what point does it Kick in or is Permanently Disabled for all Contributors that are Registered ? Ra
  #107 (permalink)
Old 03-08-2013, 6:36 AM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Since this thread has gone wildly off topic I am
going to shut it down. In the future please help keep
threads on topic.
Thanks!
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
http://instagram.com/KE4ZNR
Closed Thread
