Old 01-25-2013, 7:04 PM
Default Bearcat BCD396XT Stuck Scanning for a Service
Hey all,
My Bearcat BCD396XT seems to be stuck scanning for the Ham Radio service... I can't for the life of me figure out how I turned this on, let alone how I turned it off. I can scan for other services or programs, but it *always* includes scanning the entire ham radio spectrum in between scanning other programs or services.
Anyone know how to turn this off??? I don't even know what to search for in the manual.
Thanks.
-Chris
Old 01-25-2013, 7:15 PM
pdfdems286's Avatar
just hit the scan button.
drooling is a problem that can be licked !
Old 01-25-2013, 7:16 PM
Pressing the scan button does nothing other than three rapid, low-tone beeps.
Old 01-25-2013, 7:19 PM
W8RMH's Avatar
Originally Posted by cweilemann View Post
Hey all,
Thanks.
-Chris
It sounds like you have the HAM search assigned to a search key. Hold on any channel/frequency and press Func then the number key (1-3) assigned to the search once to turn it on and once more to turn it off.
Set Search Key
The scanner has three search keys that you can assign to a special search range. The search keys are set to number keys 1 , 2 , and 3. This allows you to start a service, custom, Tone-Out, or Band Scope search without having to go into the menus.
To program a Search Key, press Menu. Scroll to 'Search for...' and press E/yes.
Scroll to 'Set Search Key' and press E/yes.
At 'Select Key No.' scroll to 'Search Key 1-3' and press E/yes.
Scroll to any service search, custom search, 'Tone-Out', or 'Band Scope' and press E/yes.
Repeat for any other search keys you want to program. Press L/O to exit.
Easier to Read BCD396XT Digital Scanner Manual
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
_D I S P A T H C E R___O H 1 4 5
________http://www.alertpage.net/________
Old 01-25-2013, 7:22 PM
Ah, found it - search with scan got turned on... Thanks for the link to the easier to read manual - that helped!
Old 01-26-2013, 8:13 PM
cg cg is offline
You can't do it through the keypad but Proscan allows you to assign system quick keys to both Service and Custom Searches. Makes it so much easier to turn searches off and on (for those who bother to look for the unknown)
chris
Old 01-26-2013, 8:26 PM
Wiki Admin Emeritus
I'm fairly certain FreeScan also has this ability...Mike
