Old 01-28-2013, 10:41 AM
hosehead88's Avatar
Default 996XT cutting out
This is driving me batty...
It seems to happen all the time on Conventional frequencies, even more so when there are dispatches going out. The sound just drops out. I do not use priority at all, so that isn't the issue. I miss a lot of information because the sound just drops.
Any suggestions?
FTM-PTB-EGH
West Shore Bureau of Fire
996XT/PSR-600(x2)/PSR-500/Pro-2096/Pro-2055/Pro-97/Pro-2026/Pro-2036
Old 01-28-2013, 10:43 AM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
Do you have close call on?
(402) 937-8578
Old 01-28-2013, 11:00 AM
hosehead88's Avatar
No Close Call either.
FTM-PTB-EGH
Old 01-28-2013, 11:01 AM
Could it be weak signal or Interference? Or does it cut ever 5 sec like if its Priority on?
(402) 937-8578
Old 01-28-2013, 12:04 PM
hosehead88's Avatar
It doesn't seem steady enough to be a priority. Definitely not a weak signal. Could too string a signal do it?
FTM-PTB-EGH
Old 01-28-2013, 12:16 PM
Wiki Admin Emeritus
The 2nd question in this wiki article addresses these issues (all links are blue)
DMA P25 Decoding and Audio Issues - The RadioReference Wiki
HTH...Mike
Old 01-28-2013, 9:25 PM
kbehning's Avatar
Have you tried turning off Weather Priority? Hit the WX button until it says "WX PRI Off" This is different from the regular channel priority setting. Gets alot of people
http://marksscanners.com/996xt/996xt.shtml#weather priority
Old 01-28-2013, 10:40 PM
W8RMH's Avatar
Make sure your squelch is not set too high.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 01-28-2013, 11:19 PM
kbehning's Avatar
Similarly, make sure your antenna is not too low.
